SOLVED: Problem with Tabs
12 years 6 months ago #143041
-- url of the page with the problem -- : www.maglo.ch/jupgrade2/index.php/shopkat...testwein-und-so-2004
-- HikaShop version -- : HikaShop Business: 2.2.3
-- Joomla version -- Joomla! 2.5.17
-- PHP version -- : 5.2.17
-- Browser(s) name and version -- : All
Hello
I have a problem with the tabs. When I click on a tab it opens. If I click on another tab, this also opens. But I can not close.
Then I need a tab with the manufacturers description. How can I do that?
Last edit: 12 years 5 months ago by Webmediacontent.
  • Thank you received: 14186
12 years 6 months ago #143062
Edit the file "show_tabular" via the menu Display>views and change the code:
	<input type="hidden" name="selected_tab" id="selected_tab" value="hikashop_show_tabular_description"/>
<?php } ?>
<?php } ?>
and that should fix the tabs display.
Regarding adding another tab, you would have to add your custom code in that same file.
12 years 6 months ago #143074
Hi Nicolas
- The tab works. Now, however, the article appears to me four times?
- What is the code if I want to have displayed in the tab the manufacturer's description?
Kind regards
Adrian
12 years 6 months ago #143147
I do not see four times the article. So I don't know if you fixed your problem or not.
About the manufacturer description, it will require some PHP/development skills.
You will have to override the view "product | show_tabular" in order to add a new tab, load the manufacturer (ans his description) and add the content into the new added tab.
12 years 6 months ago #143296
Hello
Since problem with the multi-view has somehow solved by itself. Thank you.
I have created the tab. Find just not the code to the manufacturer's description display. Would be great if you could help me there.
what I now do not understand.
I'm trying to adapt the Product page. Now I have different views depending on the category? :-S
www.maglo.ch/jupgrade2/index.php/shopkat...iemonte-doc-monsieur
Very thanks
Adrian
Last edit: 12 years 6 months ago by Webmediacontent.
12 years 6 months ago #143357
1. You can use such code:
<?php
$class = hikashop_get('class.category');
$manufacturer = $class->get($this->element->product_manufacturer_id);
echo $manufacturer->category_description;
2. That's because you selected different product page layouts for these products or their categories (via their "layout on product page" option).
12 years 6 months ago #144187
I have that works with the tab now. Now I have changed the order. The tab with the specifications is first. But when you open the page, the Description tab is first open. See here
Then I have tried the manufacturer's link from the specifications tab below do move.
Even if I clear the code it is still on the products page.
<span id="hikashop_product_url_main" class="hikashop_product_url_main">
        <?php
        if (!empty ($this->element->product_url)) {
          echo JText :: sprintf('MANUFACTURER_URL', '<a href="' . $this->element->product_url . '" target="_blank">' . $this->element->product_url . '</a>');
    </span>
12 years 6 months ago #145563
Can you give me more information about how you want to change your product page through some screenshots for example ?
12 years 6 months ago #145571
Hi Mohamed Thelji
The appendix is ​​a screenshot.
1. The tabs should be the right of the image. The title should be centered above.
2. The tab "specifications" on the left. The tab "Description" in the middle. The tab "manufacturer" on the right. While I can move the tabs. However, it always opens the tab "Description" as standard.
3. In the tab "specifications" it has a link Manufacturer: Val di Toro.
The should down outside the tabs. Always visible.
12 years 6 months ago #145703
1. You can set a margin left on the class: hikashop_tabs_ul to move the tabs to the right like:
.hikashop_tabs_ul{ margin-left: 250px !important;}
2. You have to change the value of the following hidden input in the product / show_tabular view:
3. You have to edit the code in the view product / show_tabular to put that part out of the tabs.
12 years 6 months ago #145757
Hi Xavier
Thanks für your help.
Thanks for your help. Number 1 and number 2 is ok.
One problem I still have with the manufacturer link.
I have the following code away, but the link is still displayed.
<?php
12 years 6 months ago #145840
You have to edit the view "product / show_block_dimensions" and remove/comment the part:
echo JText::_('MANUFACTURER').': '.'<a href="'.hikashop_completeLink('category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->alias.'&Itemid='.$Itemid).'">'.$manufacturer->category_name.'</a>';
12 years 5 months ago #146366
Hi Xavier
Thank you very much. After that I was looking for. I now have the code from the "show_block_dimensions" removed and inserted into the "show_tabular".
<?php
echo JText::_('MANUFACTURER_ALL').''.'<a href="'.hikashop_completeLink('category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->alias.'&Itemid='.$Itemid).'">'.$manufacturer->category_name.'</a>';
Unfortunately, the link no longer works that way. The manufacturer's products are not displayed.
Link
12 years 5 months ago #146608
Thanks to try that code:
<?php
$categoryClass = hikashop_get('class.category');
$manufacturer = $categoryClass->get($this->element->product_manufacturer_id);
echo JText::_('MANUFACTURER_ALL').''.'<a href="'.hikashop_completeLink('category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->category_alias.'&Itemid='.$Itemid).'">'.$manufacturer->category_name.'</a>';
12 years 5 months ago #146725
Thanks, but unfortunately the result is the same.
Look here
12 years 5 months ago #146759
This code is the same as the original one, thanks to try it.
<?php
$categoryClass->addAlias($manufacturer);
If it soesn't work, thanks to create a category listing menu for the brands, and then use the same kind of link in this custom code.
12 years 5 months ago #146830
Thank you Xavier
But, the code also does not work.
How should I add the link? I have only one show_tabular, but several manufacturers.
12 years 5 months ago #147079
As I said, I think that now the easiest way to have this working is to create a category listing menu item which can in a not displayed menu.
Then see how are the urls, and edit the previously given code to adapt it to the urls given by the created menu.
You can adapt the urls and keep a dynamic brand thanks to the object $manufacturer.
12 years 5 months ago #147118
Thank you
Sorry but I do not understand how this link should look like.
Otherwise I have to see that I remain the link in the tab, but at least below the specifications entries.
Kind regards
Adrian
12 years 5 months ago #147213
Could you give us a backend access to your website in order to see why it's not working fine, and correct that ?
You can send it via PM, and in the message thanks to give the url of this topic.
Time to create page: 0.100 seconds
