SOLVED: Problem with Tabs
12 years 5 months ago #147608
Problem solved, I just edited the link to have the same than when the link is in the specification tab.
You can see the changes in the show_tabular view.
12 years 5 months ago #147704
Hi xavier
Thank you very much. Works great. Only one small detail. The view of the target page is not the same.
This is the new link as a result of: www.maglo.ch/jupgrade2/index.php/shopkat...egory/38-val-di-toro
And so it is original: www.maglo.ch/jupgrade2/index.php/shopkat...egory/38-val-di-toro
I work with the table view.
greetings
Adrian
12 years 5 months ago #147733
That should be ok now.
If it's not exactly what is expected, you can edit the view and see the examples of links I made and improve them as you wish.
The display was not the good one because the item id was missing.
12 years 5 months ago #147842
Very very very thanks. This is perfect. Great Support.
For the other. This is the Code
<?php
$categoryClass = hikashop_get('class.category');
$manufacturer = $categoryClass->get($this->element->product_manufacturer_id);
$categoryClass->addAlias($manufacturer);
    //echo JText::_('MANUFACTURER_ALL').''.'<a href="'.hikashop_completeLink('category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->alias.'&Itemid='.$Itemid).'">'.$manufacturer->category_name.'</a>';
    //echo JText::_('MANUFACTURER_ALL').''.'<a href="index.php/shopkat/category/'.$manufacturer->category_id.'-'.$manufacturer->alias.'">'.$manufacturer->category_name.'</a>';
    echo JText::_('MANUFACTURER_ALL').''.'<a href="index.php?option=com_hikashop&ctrl=category&task=listing&cid='.$manufacturer->category_id.'&name='.$manufacturer->alias.'&Itemid=197">'.$manufacturer->category_name.'</a>';
    anzeigen.</p>
Last edit: 12 years 5 months ago by Webmediacontent.
The following user(s) said Thank You: Xavier
12 years 5 months ago #147900
Thanks to have shared the complete code.
