Problem with showing products on "home"
10 years 4 months ago #236800
-- url of the page with the problem -- : www.tiendamat.com
-- Joomla version -- : 3.5.1
I'm getting a silly problem with getting products on the homepage. I asign a "product listing" to the home menu, and click on "random products". This shows random products perfectly on the homepage.
The problem comes, that I have a banner on a position above the body. It shows good in the homepage too, but there should be the only place where it should show. But then, the banner shows up on some products.
When contacting my template company, they tell me that this has to do with hikashop, since the products are on the homepage.
I add a couple of images below to try to make it clear what is happening:
Homepage:
Correct product:
Incorrect product:
Is there any way to fix this? Thank you very much.
10 years 4 months ago #236859
doesn't matter, just solved it.
It has to do with this topic:
www.hikashop.com/forum/product-category-...ut-url-creation.html
For those having the same problem, the problem comes from the canonical URLs. The canonical URL is saved the first time you enter the page, so if you enter home before entering the product page, the canonical page won't be saved correctly. To fix this, delete the canonical adress on the product, and enter the webpage directly to the product so it gets saved.
Time to create page: 0.513 seconds
