Product Layout and Description Layout Help
9 years 8 months ago #257887
-- url of the page with the problem -- : collectormotors.com
-- Joomla version -- : 3.6.5
-- PHP version -- : 7.0.12
Can anyone explain why my product layout keeps getting "screwed up?" I get it fixed and everything is symetrical and then the following happens! This time I have spent hours to no avail in trying to get correct again!
Please view (messed up) URL's below for examples; (There are supposed to be (4) products on each row!)
Then! There is the product description displaying over specifications on the product page instead of below!
See URL's listed below;
Thank you!
  • Thank you received: 14184
9 years 8 months ago #257939
1. The problem comes from the line:
margin-left: 2.12765957447%;
in the CSS:
.row-fluid [class*="span"] {
display: block;
width: 100%;
min-height: 30px;
-webkit-box-sizing: border-box;
-moz-box-sizing: border-box;
float: left;
in the file collectormotors.com/templates/lt_salon_car/css/legacy.css of your template. Remove it and it will display properly.
2.
The problem of the description on your product page comes from the CSS of your template.
It uses that CSS:
#hikashop_product_bottom_part {
position: absolute;
width: 50%;
top: 25%;
right: 0;
but instead, it should have that CSS:
float: right;
clear: none;
width: 50%;
margin-top: -230px;
in the file collectormotors.com/templates/lt_salon_car/css/default.css
9 years 8 months ago #258028
Thank you so much!!! Greatly appreciated!!!
9 years 8 months ago #258040
The fix provided above did correct the description layout on (SOME) products and (NOT) on others!
Description displays bottom right!
However, test content on the following seem to be displaying correctly!
Thoughts?
9 years 8 months ago #258051
That's because if you want to have it in a position fixed below the right part, you need to actually edit the file "show_default" via the menu Display>Views in order to move the PHP block of code of the description rather than using CSS like your template is doing.
For example:
www.hikashop.com/support/forum/4-how-to/...mage-right-part.html
9 years 8 months ago #258087
Excellent! Thank you so much, Nicolas!
