Product prices not displaying when using CSV
9 years 1 month ago #273387
-- url of the page with the problem -- : www.clydesdale.net/clydesdale-products/p.../4411-noah-coveralls
-- Joomla version -- : 3.7.2
-- PHP version -- : 5.6.30
I have a few products where I have cron job running to update product prices with a CSV. I have noticed that when it updates all of the variant prices the prices do not display on the front. I have to add a main product price for them to show. However I I created a test product manually and this doesn't seem to need a main product price for the variant prices to display.
How is this mean't to work and how can I get the prices to display without add a main product price?
  • Thank you received: 14182
9 years 1 month ago #273390
A price isn't necessary in the main product. So this indicate a problem with your CSV.
9 years 1 month ago #273421
Hello I have attached the CSV I am using to upload. Can you tell me what is missing?
This is also the link to the product page for product code CLY 582 124 ##
Last edit: 9 years 1 month ago by dancingkazzaf.
9 years 1 month ago #273436
That CSV is indeed not a valid import CSV.
If you have variants in your products you need:
- a column for each characteristic with the value of the characteristic for each variant (and the default value for the main product)
- a row for each main product placed before the rows of its variants
- a column product_parent_id where you have the product_code of the main product for each variant.
Then that would import properly through the import system and product cron update plugin.
Now what you can do is to use a mass action with an import filter instead. The massaction system is an approach close to the database structure below so it doesn't need the extra things I talked above because it has a lot less processes trying to generate stuff for you automatically and just does a simple update.
www.hikashop.com/support/documentation/167-massaction-form.html
9 years 1 month ago #273500
So I still need a default value for the main product then? Can you supply an example or edit my CSV so you can show how its all meant to be layed out.
The system that the client exports from doesn't use a main product just has product codes and prices for all the variants ence why the CSV only has them on.
There system also wouldn't have all the characteristics on, thats something that has been added in Hikashop all we really want to do is have a CSV that updates pricing?
Is there a way to only update pricing using CSV?
9 years 1 month ago #273506
To get an example of what you would need for the standard import system, just select a product configured like you want in the backend products listing and click on the "export" button.
Then, remove the rows for the categories structure and the columns that don't have any data and you'll be left with a pretty good example of what you need.
So with the restrictions you have for how your CSV is generated it's better to go through the mass action system as I explained in my previous message. With it, you don't need to have the main product, or the characteristic columns in the CSV. So do that and you'll have your solution.
9 years 1 month ago #273597
The issue is the system that the client exports from doesn't have the characteristics or the main products. This is all created in Hikashop.
Cant you just update pricing from the product codes?
9 years 1 month ago #273605
It seems you didn't understand my two previous messages. So I'll keep it short:
Yes, by using the mass actions system.
9 years 1 month ago #273677
Am I still using mass action with a CSV or using another filtering option. I have read the documentation but I still don't understand how I am mean't to just import the prices of the CSV correctly.
I have just read this post: www.hikashop.com/forum/import-export-csv...tegory-id-s-csv.html
I am already importing the CSV through mass action but the prices wont display on the front.
9 years 1 month ago #273679
You need to go in the menu System>Mass actions, create a new mass action, with a filter to import the CSV and process the mass action in order to update your prices.
If you have a problem with that method, then please provide a screenshot of the settings of your mass action.
9 years 1 month ago #273820
Yes that is exactly what I have been doing.
I have attached a screenshot
9 years 1 month ago #273845
Your mass action does not have any "action" set.
9 years 1 month ago #273866
Thanks but what action am I meant to be using?
I selected update values > then price_value but then its asking for INT, FLOAT, STRING or OPERATION and there is an empty field next to it. What am I meant to use to update the prices?
9 years 1 month ago #274156
Hello I am still waiting for help for my issue. I am using Mass Action to upload my CSV but it not work correctly. You guys said I need to setup an Action I have checked documentation but I still don't understand the values etc.
What action do I need to update prices from a CSV?
Time to create page: 0.248 seconds
