How does Hikashop work for mobile phones?
14 years 3 weeks ago #56353
Does it?
14 years 3 weeks ago #56382
If you want Hikashop or your web site to work fine with mobile phones, you'll just have to find a Joomla Template that can handle mobile phones.
Hope this will help you :).
14 years 3 weeks ago #56421
Thank you!
14 years 3 weeks ago #56452
sounds great, so if template is made as Responsive Design, HikaShop will behave in responsive manner?
HINT: Look at responsinator.com
if hikashop is made to adapt to the user's viewing environment (mobile, tablet, laptop etc.), than this is really great indeed...is it?
  • Thank you received: 14142
14 years 3 weeks ago #56521
HikaShop is not responsive yet.
We'll work on that in a few months.
However, some templates, like the mainstream ones, have a "mobile" template mode which adapts your website to mobile phones. That's different from responsive design.
The following user(s) said Thank You: woonydanny
14 years 3 weeks ago #56611
i am looking forward to responsive HikaShop, as i plan to use Hika Business in next project, and it will be very important to work well on mobile devices such as tablets, iphones and android devices.
Project is starting in 40days or so, i hope HikaShop will be responsive by that time.
Keep up the good work
Last edit: 14 years 3 weeks ago by dado023.
14 years 3 weeks ago #56614
It won't. As I said in my previous message, we'll work on that in a few months.
14 years 3 weeks ago #56615
at that time,will upgrade to responsive version be seamless, as usual?
14 years 3 weeks ago #56617
It should be yes, as long as you don't modify the views since all the changes will be in the views for that.
  • Thank you received: 17
14 years 3 weeks ago #56640
If it helps, I tend to use rockettheme templates in my websites as the have a section in their gantry system that lets you define the exact page positions to display and where to display them on android and iphone device, this is great as the webpage adapts to the device.
14 years 2 weeks ago #56723
but that doesn't change display layout of hikashop product pages, or i might be wrong...?
14 years 2 weeks ago #56753
You're right.
But there ways to achieve that.
For example you can restrict some menus to the mobile version of the template.
That way, you could duplicate your products listing menu and have one which would display for the mobile version and another one for the normal version.
Then, in the hikashop options of the menu, you could change the number of columns, images size, etc so that it fits properly.
That's not responsive but it already helps a lot for listings.
Then, for then product page, you could change a bit the code to adapt it based on the current menu:
global $Itemid;
if($Itemid==XX){
// display one way
}else{
// display another way
where XX would be the id of a menu.
  • Thank you received: 6
14 years 2 weeks ago #57227
responsive is the way forward.
thanks nicolas for putting it in the roadmap!!
14 years 2 weeks ago #57271
peetree21 wrote: responsive is the way forward.
is there a road-map, or just using figure of speech? :D ...if there is i would like to see what else is next :woohoo:
14 years 2 weeks ago #57333
It is in the road map.
Next are:
wishlist system
cart management
advanced reporting along with new widget options
badges system
lot of new payment plugins
multi vendor
All that is currently being developed here. Next will be the compatibility with 3.0, PHP 5.4, responsive design, recurring payments.
The following user(s) said Thank You: dado023, woonydanny, PolishedGeek
14 years 1 week ago #57424
yes indeed, whishlist system is very desirable for any webshop. Do you have any ETA for it, since it is already under development.
14 years 1 week ago #57426
We hope to have it in next release in august.
13 years 11 months ago #60124
i am watching close for next release, since we are already in August....do you expect it soon?
looking forward to your response :whistle:
13 years 11 months ago #60191
We are close to finishing the test phase. So either this week or next week I think.
13 years 11 months ago #60212
sounds promising :D.....as soon as it releases i will combine it with HikaSerial
Time to create page: 0.122 seconds
